Well loved the first build just had to get another!
I started with this 2005 abused orphan- :frown:
Inside the motor- Luckily the piston is in one piece... Can ya see why i wasn't getting good compression?!
The jug- scuffed non feel deep but only measuring will tell I'd be happy to keep the stock 66mm bore if at all possible!
The crank, I was able to squeeze a .021 feeler gauge in between the thrust washer and the rod at the big end sooo.... that is within spec on the higher side but in spec, no up and down play at all, seems like bottom end crank is good that's a plus!
stock intake and exhaust pic-
Wanted to keep this build cheap as possible, well ya know how that goes! was just gonna clean her up a bit throw a few new parts at it and ride.. Then it hit me all the sudden like a virus, that damn MOD bug!
Started but all kinds of goodies and just couldn't stop!
Rear Suspension $30shipped
handle bar grips (the best)-$12shipped
Oh snap, antivibe mode!!!
Sweet sweet chromoly tubing for my stem!
Tors delete for the 33pwk(not in yet).
I wasn't sure how I was gonna like a fat bar. These things are awesome gonna really set the stem up great!
Super thick and rifled insides!
Mounted!
More yet- no way if only the wife new i'm spending the tax return check all on this SHHHH don't tell her! :wink:
More parts this time super cheap! Local dealer going out of buisness gave me 40-50% of everything!
There is piviot works- swinger pivot bearing kit, lower a-arm kit, then moose racing lower a-arm kit and rear axle kit, and my favorite degreaser cleaner! all for $87 and change normally would of cost $160!
yes the header is used but the rest is spanking new!
Stopping power-
Decided since I found a super deal on these rappy250 pegs, 10 bucks, I figured I'd be different than just double pegs! I also wanted to keep the holes for mounting the heel guards the same as the stockers, well turns out the holes line up perfectly, should of figured this since alot of guys have put 450/rappy heel gaurds on.
Easy to do and the rappy ones are almost twice as wide as the little 1" stockers!
First cut off the rappy pegs at the mount-
Then remove the front piece that is higher than the pegs ( i call it a foot keeper)-
Then the back top piece that was welded on the rappy mount or the peg wont slide over the stocker.
Now ya have to grind the welds down on the middle of the stock pegs som the holes line up!
Line the holes up- center the stock peg buy using washers and bsnug it up for welding!
Weld it up and bam ya have some double wide peg mounts that use the stock heel guard bolt location!
Welded up and worked out awesome!
Side shot-
IMG]http://i1217.photobucket.com/albums/dd390/sliperhead/42281558.jpg[/img]
Motor back from KOR! Looks awesome! I:I I had Ken go through the bottom end, rebuild with a +3 stroker as I really liked my son's. Lightened flywheel & balancer! The porting was done by James SCD racing with triple exhaust ports, and a raised boost port lowered windows. Can't wait to get this project togther!
The banshee petcock (i like saying that word!)
Body armor- this is 3/4" HDPE sheet, even have some left over to make chain sliders! The larger hole is to drain the fluid! The others are to drain any mud/water sh**! I had to make it a two piece as it wouldn't bend enough! I am bolting on to the mounts I made and welded nuts on those mounts!
And the tail/brake light-
I'll get some aluminum welding going the next couple days
6061 mandrel bent aluminum tube 3/16 thick-
My new adjustable stator with 75W light coil- as the one that came with the quad was in such bad shape I didn't want to use it!
The reducer silicone boot and clamps for carb!
picked up my parts from PC'r so here's some pics! Enjoy! I was smiling ear to ear for a hour!
I've never got to do a rebuild of anything using powder coating, Gotta give props to mark from Dylans coatings in Monroeville, PA Top notch work! Thanks
Frame shots last one is with flash-
Everything-
The black textured parts and the black ceramic toomey!-
The white accent parts!- Yes I reinforced the swinger!-
    • By BruinBeater
      Hey all, BruinBeater here.  Just joined up from the Pittsburgh, PA area.
      I'm the unofficial mechanic of the extended family.  In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage.  Both have a no start condition and have been sitting for 2+ years.
    • By Atomusthenes
    • By Frank Angerano
    • By MOORETARHEELS
      I have a 2006 LT 80 done a top end rebuild and only have 80psi.  Any suggestions on what it could be.
