it only dies if you stop sussenly with the brakes and hands off the throttle I will not die if you give it gas. I am sure its a fuel related problem tied to the float and possibly the slow jet.
thoughts?
    • By Fonne
      Hi
    • By HoldenBoy
    • By Arizona
    • By Monster12ptBuck
      What are everyone's thoughts on the CFmoto Brand ATV? I can get everything I want for a fraction of what these big brand name wheelers are charging. TIA for your input. Please let's keep this nice and clean Peep's
    • By middlebrookgt
