Hey guys my father in law was bugging me to take his 3 wheeler home and fix it (get it out of the yard) so finally i said i would. It sat around outside for 4 or so years. New plastic gas tank, cdi box, spark plug wire, new carb from ebay, stripped all the old sh** that wasnt working off, changed the oil, and thats pretty much about it. Finally i got her going and for the most part it ran fine. It seems after a while it just wont start agin. New gas and a clean out in the carb usually solves the problem. Im not to familiar with a carb. I wont remove any jets or needles or anything cause im not too sure how to remove them or put them back. Anyways some small issues to start. I cant remember if the choke is on up or down, it kind of blows out black smoke for a while and then seems to go away, and the screws (2) on the carb i cant remember how many turns in or out, the idle screw seems like it needs to be adjusted all the time. If its at perfect idle the next time i go to use it it seems like the idle is too high again. but if i turn it out too much i beleive i have a hard time starting it the next time. In order to start it i usually have to pin the throttle, not sure if thats normal. For the most part this trike is awaesome and im glad i chose it as a project but I dont think im quite finished yet. Anybodys opinions would be appreciated or some suggestions as to some better parts or anything.
    • By TomJulio
    • Guest
      By Guest
    • By RGS
    • By ncutts
      hey all looking for some guidance on my KQ just replaced stator, and regulator on the quad and after putting all the plastics back together and finishing the snorkel kit she has no spark when i check voltage on the power wire going into ignition coil im getting about 12v and if i crank it im not getting my "peak voltage" (80v) any help would be greatly appreciated
      thanks , Nick
    • By Sketchy
      I've finally been able to get the plugs to spark by replacing the coils, regulator,  and cdi.  When checking the plugs for spark I noticed that they would spark for only a second or two and then no spark.   I release the start button and try again with the same results.  Shouldn't the plugs keep sparking with the start button pushed?  Thanks in advance.
