April Fools Ride !!!LOL
By jay41198
By Maxg_57
By TravisCr
By Topendcol
Col
By Mikael
I recently bought and old Kazuma Dingo 150cc and to begin with it started just fine. Then, for no apparent reason, it wouldn't start. It turns the motor but fuel isn't getting to the spark plug.
As mentioned in the title I've since replaced the fuel filter, the carburetor, the ignition coil and the spark plug. Fuel comes into the carburetor but seems to go no further. Is it a vacuum problem? Does anyone have a good idea about how I could diagnose the problem? And how to fix it?
I don't know what year it's from, sorry.
Sincerely
Mikael
