Anyone have any tricks to removing front hub bearings? i tried a blind bearing puller, drift punch from opposite sides. Could i press out the bearings and inner race as one assembly or is the race part of the hub? I heard of a oven trick but cant find it anyone know it?
Sent from my SGH-T959V using Xparent Blue Tapatalk 2
i bought a 1/2" drive socket and a 5lb hammer. the socket had just a little play inside where the
bearing seats. i also took the hubs off to make it easier. i suppose you could heat it if it's in good. but i
had good luck with the big maul and socket :yes:
I tried pressing them out with a 20 ton press with no luck. I heated them in the oven at 350° for 20 min and popped the bearings out with a drift punch and hammer with very little force. There is a machined lip on the inside of the hub preventing the bearings from being pressed out
Yeah the only thing that sucks about small shops is the turn around time. He has answered all my questions truthfully and keeps me informed as to what step he is on the motor.
    • By Elk
      2002 Polaris Magnum 325
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By Matdum
      Is there a common trouble to have the connecting rod bearing failure on a 2006 330 polaris magnum ? I have one who have failed and i want to know if there is something to check specifically
      thanks a lot !
