I have a 02 Raptor 660 and I need to put a top end seal kit on it and was worried about the timing and cam. Anyone help me out with pics or links on how to set timing just right so when I throw it together I'm good to go? Greatly appreciated!!!! Thanks.
You have to have the 2 holes that are in a line on the cam on the top center and the dot on the top gear top center and line the dot on the bottom gear up with the arrow above the gear to line the bottom gear up you have to have the clutch assembly off. Just remember everything has to be top dead center, I think you pull a side plug to check top dead center of the crank.
that is why with any engine work i have to do i take it to someone that knows what they are doing. too much there to mess up. LOL
    • By noticon75
    • By toe420
    • By Gtc4d
      Thanks.
      Todd
