By quadcrazy
Best ATV for Older Riders
Polaris Sportsman 570 EPS
Best Reliable ATV for Seniors
Honda FourTrax Rancher EPS
Best Features
Best Premium Comfort ATV
Can-Am Outlander MAX
Standout Comfort Features
Best ATV for Easy Handling
Suzuki KingQuad 500AXi
Why Older Riders Like It
Yamaha Grizzly 700 EPS
Best Features
Arctic Cat Alterra 600 TRV
Key Advantages
Electric Power Steering (EPS)
Automatic Transmission
Lower Seat Height
Two-Up Models
Hand Warmers and Heated Grips
Adjustable Suspension
Buying Too Much Power
Ignoring EPS
Choosing Aggressive Tires
For most mature riders:
Final Thoughts
By KIWINZ
Hello
My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty. He cleaned the carb and then with some either it started and still starts first pull. Its runs really nice - not rattles etc. Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine. No crunching or missed gears - just no first gear. 2nd gears appears to be as low as it will go
2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had. Other is a Quadrunner which doesn't have this feature)
3) no neutral light - will start when no in neutral - should it do that?
4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
5) checked the clutch adjust on the RHS - seemed fine to me. When i turned the screw back 1/8 it was where it was to start with. Clutch doesn't slip. The bike will move forward is all gears.
Any help would be appreciated
Andrew
By Dutchaaron
