Check out this link: http://dougmcgee.org/ATV/Resetting%20Belt%20Warning%20Light.txt
Resetting Belt Warning Light
All the Kawasaki Prairies and Suzuki Twin Peaks "same thing" activates the belt warning light at or close to every 100 hours. The only other thing designed to activate the belt warning light is a belt deflection switch located in the drive belt cover. If the belt deflection trips the switch, you must remove the cover, adjust the belt and reset the switch. If the switch has not been tripped and the belt warning light is activated only because the machine has reached a 100 hour mark the following is the reset proceedure to get you going again without the annoying blinking light. If the belt deflection switch was tripped and reset after the belt adjustment you will still follow the below reset proceedure.
Early 03 models
1. Turn the ignition off.
2. Disconnect the Belt Failure Switch at the two-pin connector above the belt (cvt) cover.
3. Disconnect both sets of the five pin connectors located on the right side just below the shifter above the CVT cover. One plug is black and one is gray. The wires are held with a couple wire holders which are easily bent to release them.
4. Connect these five pin connectors to their opposite pairs, (black to gray and gray to black). Don't break them, they are sometime hard to get apart.
5. Turn the ignition switch on and let the belt warning light flash at least 7 seconds or longer then turn the ignition switch back off.
6. Reconnect the connectors back to their proper mates, (black to black and gray to gray).
7. Reconnect the Belt Failure Switch connector, (two-pin connector above above the belt cover.
On late 03, 04 and 05s do the above in this order. 1-3-4-5-2-6-7. I have successfully reset the light without unplugging the belt failure switch at all.
      any ideas how to correct
    • By T37Mark
    • By hunky
      Thanks for looking!
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      But when trying to start in neutral, there is no click or attempt to start with the push button.
      However if i pull up on the shifter (not hard enough to shift into first though) the neutral light goes off and the start button works and it starts fine.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
      Thanks for any help you can provide.
