Similar Topics
By GTX-Racer
I am looking for a PDF version of a manual for a Suzuki Quadrunner 250. I am not sure of the year, but believe it is a late 1990s model.
By GTX-Racer
I am looking for a front battery cover for a Suzuki Quadrunner 250 (year unknown). It has the headlight on the handle bars and no speedometer.
By 97kingquad
By GTX-Racer
I recently purchased a Suzuki Quadrunner 250. I am not sure of the year. I plan on rebuilding the carburetor and looking to do some maintenance before using it.
I also purchased a Quadrunner 160 and planned on doing the same maintenance. I have the same question for the 250:
I am going to change the oil, which is simple enough, but after reading the manual there are many adjustments that are needed when the oil is drained. Does anyone have any advice on the valve clearance or clutch adjustments? Both require the oil to be drained and the engine at top-dead-center. Anything else that I should do while it is in this configuration?
I am unable to find a manual online for the 250. Does anyone know the valve clearance setpoint?
By DaDolt
So, I found myself in the only 5' deep water hole in Moab with the King Quad. Before I could get off it swallowed water at idle and died. The river water was not very clean. I pulled the plug and pumped the water out of it with the starter. I cranked on it and it popped for a second and then was done. Towed it back to the trailer. When I got home I checked the compression and it had none. I have a factory service manual. Disassembled and found the rings stuck in the piston lands. New rings and back together. I try to start it and get a C12 code CKP - crank position sensor. Troubleshoot and find it to be shorted. Installed aftermarket CKP, still get code. Check voltage on new CKP and only get 4.5V, manual calls for 5V minimum. Pulled every connector apart on vehicle and cleaned. Have continuity from CKP sensor side of connector to ECM harness. Install a known good ECM from another 2005 KQ I have. Vehicle fires and I let it run for 10 minutes. Shut it down and put the original ECM in and get a C12 code again and won't fire. Put the known good ECM back in and get C12 and no fire. Tested both ECM's in the other KQ and runs well on both ECM's. Installed a used stator and CKP. Still get a C12 code. Check used stator, 200 ohms and 6.5 V out of the CKP at the ECM harness. Checked ground at ECM harness and it is good. Checked spark with spark plug and without, none. Checked resistance and peak voltage on coil and it is in spec.
This thing has me baffled. All of the electrical possibilities seem to check out. Might be far fetched, but could the rotor key have sheared when it shut down suddenly when the cylinder filled with water? I know rotary lawn mowers can shear the flywheel key when the blade stops suddenly from a rock or stump. If the key is sheared and the flywheel is out of time by a few degrees could this be giving the C12 code? The voltage output is correct but at the wrong crankshaft position (wrong time).
Similar Tagged Content
Gallery Images
