That's pretty funny. You know, I thnk she has a real good chance of winning the election.
1. It will get Bill Back in office, the country was better
2. There's not much dirt to bring out, they've been in the spot light already.
3. She stood by her man after he cigared Monica Lewinsky!
4. People like her.
    • By mikeexplorer
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
      This is from my side drive to the top of the property.
      The Dog loves the runs.
      No snowflakes were injured in the production of this video.
      https://youtu.be/tKjBFuHCkM0
    • By Rich1028
      Video from last Saturday on the Denton Trails...PONDS!
    • By Rich1028
      Video from Leota Michigan on our Honda 400's
      5-30-2020
      Was A nice Afternoon.
