got a 2011 linhai 4 wheeler that shuts down after about a mile and then will not crank for several hours anybody got a solution?:aargh:
If it won't crank it sounds like the battery is going dead. Check your connections and test the charging system. If it re-cranks and fires up after a few hours i'd assume the battery is pretty healthy, just not getting charged.
    • By Yamahahahaha
    • By cruteg8
    • By sunn
      Any ideas?
    • By joezee13
    • By middlebrookgt
