Ok so i have ben workin on this fourwheer for months had it running great at one time i rode it one mornin it did great i went inside for an hour came back out to go ridin again and didnt crank
It will spin and wont crank there is no gas getting to motor i have rebuilt cleaned soaked my carb in gas even tried different carb gets plenty of gas to float float works properly and has good spark and battery is good
I poured gas dirctly to engine got it to crank but now wont crank no matter what
Suzuki king quad 300 4x4 1991
Ok thanks and theres is also a vaccum operated fuel pump on this it dosnt work but i have bypasses it with another gas tank higher than carb but will it still not start with the other ones not being pluged up corectly?
Check the oil level, if you where running it super rich you may have dilluted the oil with gasoline while trying to get it to run. I've seen that happen, especially on an older bike when the ring clearance has opened up a bit.
Ok got it goin great went for a joy ride with daddy and it did great got hot a couple times but i still need to adjust valves rite but now wen i start it the plug were plugs up to the spark plug device is smoking wont start its strange its like something got shorted put i duno what please help???
Ok it did great wen i went for a ride for about an hour and half but wen i got back turned it off and it wont start its electrical smoking were the cable plugs up to the spark plug thing all cables are hooked up corctley please help???
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
    • By sunn
      Maybe someone has the answer to correct a long cranking but did start after maybe 10 seconds?
      Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted.  The atv started, but then died a couple times after repeated attempts.  But when run awhile everything was ok.  Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
      Is this typical of a failing fuel pump?
      I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM.  Just had all covers off so looks really easy to replace.
      Any ideas?
    • By baller74
      Hi here's the other half of the awesome deal on a quad!
      grumbles when I went to look at this quad the seat was off and the headlight was laying aside the tank. first things I noticed  was the wiring or wires that were cut to the cdi box and the ignition switch also the seat was  off and the fuse off the battery was removed  next was the jumper  cables hooked up directly to the 110v house plug and the smell of burnt plastic and wire permitted the area. the guy selling it wasin a pinch and eeded quick cash so I overlooked my gut instinct and did a quick tally of cost and parts if I had tobuy the whole  electrical system  essentials to make it run again and slowly let the numbers 50 fly out and shut up. the foot crank was stripping bolt snapped  but I turned it over  good compression . this quad was clean as a whistle like brandnew  andthe harness so far is in excellent shape. I stopped at a friend's house and found a kymko cdi since box was actually the maker of this engine. fo free and began my next days adventures dreaming that the wind would be in my face and the cops at my back way behind me hauling as* round town In a couple hours I mean he said it ran just fine the day before ....
      well it's 715  this evening and I'm still trying to find a factory service manual that is free I can download at least the electrical schematis and conponant pinouts with wire color  and a troubleshoot guide with component testing procedures as there more than six wires for the cdi the leftovers are green green with yellow   babyblue and brown with yellow  no eof these are hooked up and she's a dead horse hoping someone could walk me threw them and there correct designation not just spliced I to a hit etc. the wires I hooked to the cdu are white pickup pin 1, blackwhite the pin 2, blackgreen ground pin 3  4 empty  2 plug  slot 1 empty slot 2 brownyellow power. now no been arguing with crapgpt all day sYs the 2 plug 6 wire ac cdi is the oem match for this one. now there was t a cdi when I bought it was "lost" probly along with the "KEY" but the cdi I pulled up shaws a 2 wire boobs 2pluh 6 pin cdi need to know if I can make her go with this cdi I looked at the wiring to that one And shows the stator hot and cold go to those extras  not sure but I am leaning towRd there's N internal voltage regulator built into that cdi box. anyone have the skinny on this I have  a voltage regulator 5 wire from another bike new bit has a pink wire when I put jumpers from my jeep to the battery and fused the hot side up  and tied the red and brown side on it switch no get nada but have voltage from battery to start solenoid  to the cdi hot pin the main harness connectors the headlights the green with yellow and  all the red wires read that brown with yellow is an accessory wire 12v switched used for engine control restrictions  but won't run without constant 12v if this is true I want it bypassed I. 205 pounds and little 200 is gonna struggle enough hauling me don't need any extra help there and infact if anyone can give me a few parts number to buy for some extra preformace and horsepower. I'm on a beer budget after my superchargered wrangler build so pheniox racing gurus and backwood tweeker brothers your input will be invaluable but you would add what you know. alright guy let er ripp I'm all ears.
    • By 97kingquad
    • By TravisCr
      I don't know if I shouldn't have posted but I this is my second post on this (other was in regionals Forum)  The family has a 2-up 2004 Artic Cat and a 2003 Polaris Sportman and we are looking for fun/easy rides in the Colville, WA area- 70 Miles North of Spokane WA, we have a small trailer we can haul these with but need to find some good areas for beginner.
      Thanks in advance for any suggestions.
