2000 Yamaha Warrior with no spark! (surprise!)
By
warriorkid97, in Yamaha ATV Forum
Similar Tagged Content
By Aj Hurtibise
I have a 2000 Honda trx90 I got from a buddy for free he said it needed a carb so I put his old carb back on it to try to get something out of it and it does not have any Spark. I already replaced the ignition coil I don't know much about four wheelers but I am a technician so I do know my way around a motor any electrical help would be wonderful or specs I don't have the best digital multimeter either.
By JPEDRO
So when im ridding in high gear randomly sometimes it will go into a persay limp mode and only allows a max of 30kmph and it sounds like a rev limiter, what would cause this and how to eliminate this all togeter as in the new ones with the over ride switch. its the sound that it does in low range or reverse. i want this gone period when i get stuck in mud i cann spin tires fast enough. and while im in high gear i dont want this happening. if you need more details the easier way of getting a hold of me rather then the forum is my email [email protected] i dont have time to check back here oftern but i get my emails right away.. thanks guys
By Christian Brindle
I've already posted here once about this ATV. Lots of people suggested i check the cam and after a couple months i finally got around to attacking it. I got it all apart and got the cam/rockers out. I'm almost positive they need to be replaced, they're pretty scored up and don't look too hot. Just wanted some final opinions before i drop the money on it. I'll also take feedback on the new cam i've chosen.
Old Cam:
New Cam: https://www.amazon.com/hz/wishlist/ls/2GM2J05FQQPCD?ref_=wl_share
Old Forum:
Thank You.
By johnwayne
i have a 2000 suzuki king quad lt-f300f that i picked up as a project bike. it didnt run well when it was parked outside 5 years ago. it cranked after putting fresh gas - but would not run below half throttle, i took apart the carb, cleaned debris, and re-assembled. i suspect that the pilot needle is sheared off - it never protrudes into the throttle body through the pinhole. now to get the bike to ALMOST idle, the throttle idle adjustment knob is all the way up/in. the pilot needle is turned almost all the way in/up (if i understand correct, it should nominally be out 2 1/4 turns or so). and like i said, it will ALMOST idle. floods easily, rides rough.
wanted to hear from those more experienced than me with suzukis - and im self-taught atv repair, so dont laugh too hard if my verbiage/part names is way off.
facing the driver's side of the bike [US] there are three hoses on this side of the carb. without a service manual or way of knowing what was messed up before i got it, i think i have them right: front hose as a vacuum to the petcock, middle hose as vacuum to the fuel pump, rear hose as fuel line from the fuel pump. running the bike in prime position results in flooding even while riding. with all hoses disconnected from the carb, fuel slowly drips from the vacuum line connected to the petcock.
so just my speculation is that the diaphragm in the petcock is split, and the pilot needle is broke off - causing my inability to not quite idle and the rough ride. this suzuki is hoses and cables everywhere compared to the honda ranchers and yamaha warriors i am used to. I would like to have a plan rather than: replace everything at once.
is my speculation on the right track, or could something else be at play? say, if the compression was non-existent, would that cause non-idling? i am all ears, look forward to the input.
By skymankila69
I traded my dirt bike for a 2000 arctic cat 500 semi automatic. when i went to go pick it up the guy said it didn't get spark, so i thought it was going to be something simple like a coil. well it wasn't. first thing i did was take all the plastics off to get easy asses to every thing. so i bought a brand new battery for it seeing if it got power, it didn't. the dash wouldn't light up neither would the lights, so then i tried to see if the starter worked it didn't so i jumped the solenoid and the starter started turning over the motor. so i bought a new starter solenoid, when i installed it the electric start still wouldn't work , so i bought a new kill switch and starter switch that goes on the handle bars, when i installed it, the electric start still wouldn't work. so then i went to see if i could get spark by pull starting it, i didn't get any spark, so i bought a new spark plug, and guess what, still no spark, so then i bought a new coil for it to see if that would fix it. so i installed the new coil and guess what no spark still and still no power to the dash. so to sum it up i'm not getting any power any where to the four wheeler. so i cleaned all the leads and plugs and still nothing. so then yesterday i took the wiring apart to see if their was any frayed wires, and no their wasn't. does any one have any ideas what this could be i'm up for anything. also if any one knows how to bypass all the wiring just to get it to start i open to that to, or if someone knows where i can get a wiring diagram.
Similar Topics
By NoahJakavi
Hello i have a linhai 300 of the 2004+- era. I had a cluch problem so we changed it. After changing it has a hard time to start going. When you pop it into gear and press the gas it barely drives but when it starts going about 20km/h it start driving well the acceleration is normal and everything do you have any idea of what could be the problem
By Ed Morris
I have a 2001 Quadmaster. Bought it from the original Owner. Its in Excellent condition for a 2001. The guy said there was a carb problem when I bought it. It seems like it is not getting fuel. I took off the tank, cleaned it, replaced the gas with fresh Gas, Installed a New Gas Valve. Then rebuilt the carb with a Carb Kit. Started it up and same damn thing, seems like its starving for gas. It will also backfire out the exhaust while trying to accelerate. Now the weird part. I started it the other day and it ran great. We went for a ride and it ran as if nothing was wrong with it. Started it the next day and back to running crappy again. I was like WTF !!! ... Anyone have any ideas of what the problem could be?
By VikingTrad3r
picked up my third timberwolf 250 for my daughters. these are great light weight little quads.
have a strange one for you. the quad will NOT start in neutral. it will start in first.
if i lift up on the gear selector just enough to hear the little click (its not loud, sounds like a contact clicking, perhaps the neutral safety switch?) the light will go out, but it won't yet be in first either. that is how i have shown my daughter to start it and she can.
id like to carry out whatever repair is needed. i have the pdf of the shop manual but it doesn't really have a flow through diagram.
any help appreciated! thank you.
i need to add something. it feels like i can switch into another gear BELOW neutral.
so if i switch to neutral, i can keep pushing the gear selector, and it has another click below the neutral. the light stays on, and when i pull up into first it kind of feels like it has two positions it moves through to arrive at first.
By texaskaw
fighting this thing for a month now.No spark at plug.
New ignition coil,pick up coil,stator,reg/rectifier,all new wiring.Started it up today rode for an hour shut it off.Tried to start later wont start.pulled plug wire it firing a blue spark while starter button is pressed.Tried new plug no change. It stared a couple times an ran for few seconds then died.Will CDI act this way? The reg/rectifier get pretty hot is this normal?
By cody75
2016 sportsman 450ho cranks. Good spark, removed injector getting fuel no check engine light no start
