By ButchM
By dkgg5755
By Jason39
By Southbitz
hi im new to this but have done oil drains on my dirt bike
but I took wrong drain bolt out of my quad.: Ive emotied the gear box oil and what appears to be my chain tensioner part. Drained oil out both plugs thinking it was my engine oil!!
I’ve refilled the gear oil from a oil point and not the engine oil as I’ve done that through the dipstick refill point… im just really worried about the oil that came out the tensioner part .. will there be a refill point for that separate from gear oil refill. Ives struggled for 4 days for information and goung round the bend.. Chinese quad is a 10ten 180 RXR
please if someone could answer this as I’m worried to run the quad until I’m sure I don’t need to find another fill point for the tensioner part ?
