By mikeexplorer
By drobbie98
Hey all, Thanks for having me in the forum. I just purchased my first ATV and am stoked to understand more about it.
The first stupid question will be, what is everyone's maintenance schedule? DO yo follow the recommended intervals or build one yourself based on the machine.
Thanks in advance.
By DayBreakJim
20230725_171507.mp4
By thelostjs
A new series by mike sabo called top quad 3 and sxs blog has a recent series called cheap quad challenge. both have taught me a lot about how fun and affordable offroading in smaller machines can be..
I just bought a cheap LAKOTA and i'm in the process of getting it trail ready i cant wait!
Let me know if anyone has seen this and what thoughts you've had. it was a incredibly helpful thing for me as i didnt know the lakota existed until i saw the show!
By Ulfthednar
Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
This is from my side drive to the top of the property.
The Dog loves the runs.
No snowflakes were injured in the production of this video.
https://youtu.be/tKjBFuHCkM0
