Went some where different and rode some trails !!! Temps in the 60`s and no dust !! Trails were tacky and fast !! Heres some pics !!! :yes:
3rd ride after breakin my wrist in june :yes:still hard to hang on with a brace on but I`ll live with it !! :laugh:
    • By joezee13
    • By middlebrookgt
    • By Ejwill
