Hi,
I have an old '88 LT-4WD, and it has been sitting for about 3 years. A few months ago, I re-built it, including cleaning the carb, changing all the oils, re-did alot of the electrical, bled the brakes and cleaned out the master cylinder, replaced the rings, valve seals, oil seal, and gaskets. (among many other things) It ran fine for awhile, but now it has trouble starting. For awhile it started with full throttle and the enricher down, but not even that works now. I have spend many hours trying to start it, and havent had any luck. I replaced the spark plug, (it had good spark, but may not have under compresion) I also took the carb apart again to see if somthing plugged the jets already, but they were fine. I am just baffled. Any idea's would be appreciated.
Thanks!
Mike
When I re-built it, I put a new plug in, and it looked fine. Definately not fouled. I put the old plug back in to see if that was the problem, but it didn't make a difference.
Try pulling the plug and spray some wd-40 into the cylinder, reinstall the plug and see if that makes a difference. I would recommend doing a compression test before and after doing the wd-40 trick to see if good compression
I just went and put dw-40 in the cylinder and still no change. Unfortionately I don't have an adapter for my compression tester that works with this small size plug, so I don't know what happened with the compression. It has always felt good, but I have never put a tester on it to make sure.
Yes, I am getting fuel. I have good spark, and as I said above, I have tried 2 plugs. I just re-built the cylinder, and am pozitive the timing is correct. It ran for about a month after re-building it and the timing was fine, so unless it slipped, I don't think that is the problem.
It is the 250. I have a service manual for it, but the trouble shooting doesn't go very far beyond checking for spark and fuel.
I will get an adapter for my compression tester asap.
To test the spark, I leave the plug in the boot, put it close to the frame, and turn it over. The spark idn't that strong, but it is enough to arc to the frame. (about 1/8")
I've seen these engines run with almost no compression. I wouldn't sweat the compression test. The stroke is so long that you would have to have a gaping hole the size of your finger for it not to develop enough compression at starting speed.
3yrs is a long time. Did you clean the crud off the inside of the fuel pump? How about the petcock? That could be dumping gas into the vacuum line if the diaphragm is torn. That's a VERY common problem on these quads. How did you clean the pilot jet? I had to use very small drill bits on mine (like #90 and higher). I thought I had the 37.5 pilot clean until I saw the 35 pilot I had was bigger. So I had to drill it out again. Its amazing just how hard and tough that crud is that gas leaves behind. Its almost as hard as the brass! Guitar strings or bread ties make good jet cleaners. Also clean the little holes in the carb itself. Not just the jets. Those holes are hard to get to. A guitar string works good for that.
For hard-starting issues I always verify the intake valve has enough lash. Its pretty well known how hard it is to start a cold engine if the intake valve has no clearance. Since you just rebuilt it and it ran for a while, I would check that 1st. If the valve is tight, then you have dirty air passing thru your filter. Now that the hardness is worn off the valve, this will happen more frequently until the valve is finally worn away and pulls thru the head. I've seen this a lot on these heads and its pretty much a given when one rolls in my shop.
To test the spark, I leave the plug in the boot, put it close to the frame, and turn it over. The spark isn't that strong, but it is enough to arc to the frame. (about 1/8")
gotta be bright blue and rapid fire consistant ... yellow is weak ....
Yes, I cleaned the fuel pump. Haven't done anything with the petcock though. I know for sure that the carb/jets are cleaned out well.
I will check the intake valve. Its a pain to have to take the head off again...
Oxidized, the spark is bright blue, and for this small engine, should be strong enough.
Thanks for the tips guys.
There are caps on the valve cover with big nuts on them. Like a 21 or 22mm socket. I can't quite understand how one can be savy enough to assemble the engine, but not know about the valve adjustment access holes.
The big round holes:
If you put the head on I hope you didn't use too much RTV on the valve cover or it will squeeze into the cam bearing quite easily. It will burn up the cam bearing and make the head junk.
Thanks for pointing them out. Pretty funny I didn't know! This is the first small engine like this I have rebuilt, so bear with me. I have worked mostly on cars.
I used very little RTV for that reason, and would be very supprized if any squeezed out.
I have been working on a 1987 lt4wd for the past year or so. My experience, the carb may be the issue. I rebuilt mine 4 times (moose parts), soaked, sprayed, everything. Finally broke down and bought a carb on eBay. Installed, started right up. Idle was uncontrollable. Replaced the throttle cable, runs perfectly now. Besides a slipping clutch! If you rebuilt the carb go back to the original parts, and check the cable for play. Good luck. Dan
Hey guys, I have been really busy so I haven't done anything on the quad till today, when I checked the valves, and both valves are working properly. I have tried pretty much everything I can think of. I am going to go through the carb and fuel pump once more, just to make sure they are working properly. If that does not work, should I pick up a new carb to try it out?
Thanks!
    • By docdoug72
    • By RadRob
    • By Thumpinhard25
    • By Dumass
    • By Trent Finnessey
