By HighPlainsIT
My son's trying to get a 2003 Prairie 360 running. Over a year ago, he'd rebuilt the carburetor using a SHINDY 03-112 rebuild kit from JT Cycle & ATV, and it was working fine; however, when it wouldn't run recently, he took the carb apart and the jet needle was rusted in place. He cleaned that up as good as possible and replaced the jet needle with the old one that wasn't rusty. Now, he can only get it to start about 1 out of 5 tries, and when it does start, it won't run unless the choke's on. The spark plug's good and is sparking. It has compression. Any ideas on what he should try next or look into?
By Gwbarm
I pulled out my Big Bear needed to do a few things probably havent been started in a year. Gassed it up charged the battery started right up. I have been using it around the property for this and that. Went to hook up my trailer to pull up to the house while it was idling it quit. Went to start it turned over but wouldnt start. After trying a few more times lost all power. Pulled it up to the house with the John Deere, the first thing i checked was the Universal fit soloenoil from Amazon and it was only a 10 AMP fuse so it does not universally fit the big bear it should be 30 AMP fuse. At the time i remember noticing it but forgot, at the time i had other problems like wiring harness being in a box stuck engine and no spark. when i bought it, yeah i know, thats one ishould have walked away from, but if i go to the trouble of hooking up my trailer and going there, its following me home.
Thats old news, i still need to check it all out see if it lost spark and see if the starter shorted out it was acting kind of sluggish, i replaced the fuse with the spare 10 amp and blew immediately. I will try a 30 and see what happens.
By shorty
First ATV but owned 2 wheel versions all my (long) life. 1990 KLF300C for $500.. doesn't run yet but I'm an old automotive mechanic so not worried. Only a little concerned about the price of parts, certain this antique will need many
By Ant-Knee
I recently picked up a '97 Prairie 400 4x4 that didn't run. I didn't get much information from the previous owner except that it was running a couple of weeks ago, then started losing power. After that, it just wouldn't do anything... no crank, no start. The electric start didn't do anything and the pull start seemed locked up. When I got it, it had no fluids whatsoever—no oil, no coolant, nothing. I figured the engine was seized. I took the pull start recoil off and tried turning it with a wrench but it didn't move. I took out the spark plug and put some lubricant in the spark plug hole. After a while, I was able to get it moving and it turns now but isn't super easy to turn. I put oil and coolant hoping it would fire up but still nothing. I took out the starter and tested it and it worked perfectly. I tested the starter solenoid and it clicked so I assumed it is working. The battery is good and holding a charge. I also put in a new spark plug as the old one was somewhat corroded but didn't look that bad. After I tested the starter, I put it back in and ran some power directly to the starter. It started cranking the first time I gave it power but didn't do anything after that one time.
Any ideas of what I should do next would be greatly appreciated. Always wanted a quad so I really want to make this work but not sure if it is do=able.
By Kansasprairie400
Was riding my prairie 400 the other day started to miss out and then just died no spark I pulled the seat off. The battery was swelled up. I replaced the battery would not start no spark pull the control unit and there was a round quarter inch hole broken out of the Gel coating on the back. I figured it was an internal issue and ordered a new module still no spark, replace spark plugs and coil still no spark. I’ve checked all the wiring and cannot find any issues. I am not that tech savvy and really need some help. Anyone have any ideas? thank you.
