2004 Honda Rancher AT 400 Slipping Transmission
By fixitforfree
I have a 94 Trail Boss 250 2wd that will not go into forward. Reverse works great but forward just clicks but won’t engage. I’ve verified the shift lever is pushing far enough so I believe I have either an engagement “dog” or mating forward gear that are likely bad. I also see a fair amount of metal on the dipstick magnet. But if I ride the machine in reverse the gearbox seems quiet with no other issues by what I hear. That said I’m in process of pulling the gearbox to see what parts I need. The gearbox has 1341124 as the model number as shown in the photo below but I can’t find any gearbox on eBay or the Polaris parts site that matches that number. Is this 94 model a year that used some special gearbox? My tag on the box even looks different than all the tags on gearboxes I see for sale on eBay. I really want to buy new parts for the ones damaged in my gearbox to fix the one I have but just doing research at this point to see what gearbox I have to know which parts I need. Anyone with experience with this I welcome some advice or direction from what you have learned. Just FYI this machine is new to me but cranks, runs and idles perfect. It’s not beat up and will be a gem when I get this tranny fixed. Thanks.
By tcd
Ok recently got a "what i believe" is a 2003 rancher 4x4. I believe it is a 350te. Obviously a project. Wire harness was in bad shape.
Reconnecting wiring harness. Have one harness that does not match...... the end or front side of the harness has this harness. .... appears to be the one that connects to the dash./ LED indicators... The only wires (indicators) that I can find that does not have a match to the main harness connection. These 2 harnesses do not appear to go together . it appear the harness or dash cluster were changed and don't match. Dash/indicator light wire harness was cut off. Attaching pics of both connections. Is there a way to make this work or do I need to buy a new harness or cluster?
By Daniel1971
I have a 2009 Honda rancher that has fuel coming out of the injector but will not crank. I can spray gas in through the breather and it will run a few seconds. Any help appreciated
By pastorjeep
Ok guys, I am a glutton for punishment! I picked up this 01 2wd Rancher because the plastics looked good on the marketplace. It has been sitting in the guys back yard for 10 years. The original engine blew and they swapped in an electric shift 4x4 engine. 😒The engine is locked up and was full of water. The wiring is hacked where they tried to get it to run and the rear end needs new swingarm bearings where they left it laying on the ground in the woods for 10 years. Has anyone here ever did the engine swap? First thing is to straighten out the wiring and get the engine free to see if I can get it to crank over. I have swingarm bearings ordered and a new ignition switch. So hopefully I can at least roll it around soon. 🤣
