Similar Tagged Content
By johncb
My mother has a 05 John Deere 650 trail buck ext and someone told me that can am made the atv for JD. I was wondering what model can am it would be so I can find a service manual for it.
Similar Topics
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By Maddie3142005
Bet you've never seen a Tonneau cover that can hold 2 - 4-wheelers on top of it. This is a home-made heavy duty fiberglass truck bed cover that was used on an 2000 F-350 with an 8' bed. We have used it hundreds of times but are getting out of the 4-wheeling fun. You can waterproof with a rubber seal, not included. This leaves the area under the cover open for all your gear and firewood. It is white and in great shape. 4-wheelers NOT included.
By Roy Anderson
I have had a 2002 Suzuki King Quad 500 for almost a year. This is a question I’ve posted before, but likely missed the answer due to being new to the site. Here’s the issue. When in 4 wheel drive, especially in low range, especially when pulling a load downhill, I hear a lot of clanking in the front end. As if the front drive shaft was binding then unbinding. A friend who had a 1987 Dodge 4x4, told me all the noise his front end made when in 4 wheel drive was entirely normal. So, is this something I should worry about? I have all the bodywork and tank off right now doing a valve adjustment and carb rebuild. If I gotta do something, I’d like to do it now. Lastly, I’d love to find a carb tuning guide for this era of Mikuni. Haven’t tracked one down yet. Any thoughts of where to find one? Great forum. Have really enjoyed it so far.
By technofarmer
Hey there, i have recently put a new drive belt on my 11 Polaris Sportsman 500 H.O. It has 44 miles since putting the new belt on and should be nearly broken in as i hear it takes 50 miles to do so? Anyhow it has had a little trouble with slipping since i put the new one on a few months ago. Now whenver i go down a hill the belt seems to be getting caught in one clutch if not both and then it has to run a high rpm just to go a low speed. Today it did that again going down hill, i stopped, put it in neutral and when going back up the hill i had to turn it off, put it in neutral, let it roll back down the hill a little, then restart it, low range and it was slipping but thankfully i was able to make it up the hill.
So what might the problem be? Is this a need for another new belt? New clutches and belt? Or just get something else? BTW the brand new belt i put on it, is a factory one, an exact replacement for the original.
By Curtis01
OK, sooo I finally did the old skid plate and screen removal to clean out my oil sump during an oil change... This bike only has a couple thousand miles on it. Runs like a top still... Very few issues over the years after buying it used.
But boy I wasn't expecting to see this! Piece of a circlip, stuck up in the screen, and a another shard of metal and maybe a piece of gasket material. Nothing in the oil but that... Pristine otherwise, and still runs like a top. Always has.
Soooo, is it a wrist pin clip? That's the only thing I can think of like this that could end up in there. But definitely wanted to throw it out to guys that have seen the innerds of these more than I have.
The valves on this thing are still within the factory spec even. Been a really good lil workhorse...
Any other ideas?
