I blew a belt a yr ago ,then replaced it and flipped the belt switch all was good for a while ,then the lites started to blink on dash so i opened the belt cover an found that the drive pulley was bent so i replaced it all looked good 1in drop on belt as to specs .but now i cant get the belt lite to reset .so i have no power an runs like crap and no 4x4 .i need this machine for plowing the mountain drive i live on .iv been to about every site i can find on pc u tube was helpful but .the problem is they all talk about a black an gray plug on the right side of motor under the shifter that u revers the plugs for 10 seconds an all is reset .but i don't have 2 plugs .i only have 1 and there is a secondary insert that can be removed and then u can revers the plug and plug it back to itself to revers the, polarity i think .am i missing something here .any help would be appreciated .does any one have this type of wiring.and can tell me how to reset the computer so i have full power and can use 4x4 again . Thanks mtman
if you get on youtube and search it they have several videos on how to reset the belt system an they work... you also might need to make shure the belt sensor is clean and in the rite position .. they can be knocked out of alignment and keep it from reseting ...it could also be bad and cause it ...
if you cant find it on youtube and figure it out that way the clymer manual explains it step by step if you can find 1 of them ... several atv sites have them listed as down loads ... u might even find it on here ... or ask ..Oxidized_black ...he has about 100 manuals on a storage site for down loading ...
thanks ,but all the infomation that i have has come from utube,as i stated in my post .i need something beyond that .my wiring is different then what they talk about .i dont have a gray and black plug i only have one black plug with a double female side u can remove one sleeve of the female side and this allows u to turn the male end around an plug it back in in reverse but thats not working for me.
look on youtube for other kawasaki V-TWINN powered machines that have the belt drive system .. the V-force 700 ,,,prairie 360,,prairie 400,,,bruteforce 650 an 750 .. and see if that will help.. i know that some of the wire plugs are not all grey an black .. some are both black... its a crazy setup .. but i have done it and went through the same thing .. i own 3 of the kawasaki's with the belt drive system ..
ok... i did alot of searching on your machine and there was a problem with alot of the 02 prairies and alot of them had the wire harness replaced at dealerships an when the dealer ordered the new harness they got them and had the same color plugs on them ... i found this out through my local kawasaki dealer and service department ... you should still be able to do the prossess at swaping the plugs an doing the reset as u find on youtube ... if not you will have to find a dealer that can do it and show u how to for further resets ...
thanks for your efforts .what u suggest is what i have been doing with no luck,except the paper clip jumper .cuz i dont know what wires to jump and dont want to fry anything. .i bought a wiring harness off ebay and changed the front section and all the relays and diodes that are by the shifter to the ignition .i did not change the key .still no luck yesterday i had the computer unpluged an turned on the key an the lites still were blinking .this makes no sence to me if im supposed to be resetting the computer,it must be a relay i did test the diode with an ome meter it was as it should be today i will try to test the relays .as far as the dealers around here i burned my bridges at one and i think i know more then the mechanic at the other and the third wont even talk to u .its just drop it off an we will check it out .AND GIVE U A NICE FAT BILL weather we can fix it or not.thanks again
Drive Belt Failure Detection System:
The Drive Belt Failure Detection system consists of a switch mounted in the CVT cover that can be tripped by a worn or damaged belt.
If the Drive Belt Failure Detection switch is tripped, the Belt Check Indicator light will flash and the vehicle will enter “slow mode.”
In slow mode, the vehicle is limited to 3600 rpm, and the vehicle will not enter 4WD.
Other Conditions :
The Drive Belt Failure Detection system can be activated due to sudden changes in voltage.
Several common conditions that can activate the system:
Other Conditions :
• Disconnecting/connecting the battery with the key in the ON position, this is common for new units during initial setup.
• Use of accessories that have a significant draw on the battery. The Drive Belt Failure Detection switch sends voltage to the igniter.
If the battery is connected or disconnected when the key is in the ON position, the igniter reads the sudden change in voltage as
the switch being tripped.
All KVF Models (Except KVF650-A1/B1): KVF360-A/C, KVF650-A/B/D/E/F/G/H, KVF700A/B/D, and KVF750-A/B/C models have both an hour meter feature and a
Drive Belt Failure Detection switch. KVF360-A/C
NOTE:
On KVF360-A/C models, the Belt Check Indicator light is illuminated after 100 hours has accumulated.
o
BELT CHECK INDICATOR LIGHT
KVF650-A/B/D/E/F/G/H, KVF700-A/B/D, and KVF750-A/B/C
BELT CHECK INDICATOR LIGHT TRIP METER/ODOMETER/HOUR METER
NOTE:
o KVF650-A/B/D/E/F/G/H, KVF700-A/B/D, and KVF750-A/B/C models have a Belt Check Indicator light and a viewable hour meter in the LCD meter.
If 100 hours has accumulated, the Belt Check Indicator light will come on and stay on. If the Drive Belt Failure Detection switch is tripped,
the Belt Check Indicator light will flash and go into slow mode. If the light is flashing, the switch must be placed back into the ON position
prior to completing the resetting procedure. To reset both the Belt Check system indicator and the Drive Belt Failure Detection system, follow these procedures:
KVF360-A/C, KVF650-A2/B2/D/E/F/G/H,KVF700-A/B/D:
If the Belt Check indicator light is illuminated or blinking, first check the condition of the belt. Following the procedures in the
service manual applicable to the model being serviced, inspect and replace the drive belt as necessary. Once the drive belt has been inspected,
the Belt Check/Drive Belt Failure Detection system must be reset. Use the instructions that follow to reset the system.
NOTE:
o The belt switch (toggle) inside the CVT cover must be at the “ON” position before performing this procedure.
1. Turn ignition key to the OFF poison.
2. Disconnect the 2-wire small black connector by the right-front side of the engine. .
3. Disconnect both black and gray 4-wire connectors in the same vicinity (under the seat on KVF750 models)
4. Reconnect the gray plug (male) connector to the black receptacle (female) connector.
NOTE:
o Do not connect the gray receptacle (female) connector to the black plug (male connector) or the procedure will not work.
5. Turn the ignition key to the ON position.
6. Make sure that the belt light [A] flashes fast 5 times at an approximately 0.4-second interval, then slowly at an approximately 1 second interval.
7. Wait two seconds or longer while the light flashes at a 1-second interval.
8. Turn the ignition key OFF.
9. Reconnect both gray and black connectors to their correct matching colored connectors.
10. Reconnect the 2-wire small black connector.
11. Turn the ignition key to the ON position.
12. Confirm the belt light is OFF.
KSV700-A/B/C: KFX700 models store engine running time in NOTE: the igniter and the Belt Check Indicator light is o The hour meter resets immediately when theilluminated
after 100 hours of engine running time. key is turned ON.
When the Belt Check Indicator light comes on, follow these procedures to reset the hour meter:
1. Turn the ignition switch OFF.
2. Inspect and replace the drive belt as necessary according to the service manual (P/N 999241315-05).
3. Remove the seat.
4. Locate the two, 4-pin connectors under the seat. One connection is black and the other is gray.
5. Disconnect both sets of 4-pin connectors, and reconnect the 4-pin connectors to their opposite color, i.e., gray-to-black and black- to-gray.
A. BELT CHECK INDICATOR LIGHT 4-PIN CONNECTORS
A. GRAY-TO-BLACK; BLACK-TO-GRAY
6. Turn on the ignition switch.
7. The Belt Check Indicator light should be flashing.
8. Turn off the ignition switch.
9. Disconnect the mismatched 4-pin connector sets and reconnect them normally (black-toblack, gray-to-gray).
10. Turn on the ignition switch and confirm that the indicator light is no longer on.
KVF650-A1/B1:
2002 KVF650 models have a Drive Belt Failure Detection Switch located in the CVT cover and an hour meter in the LCD meter.
If the switch is tripped, the LCD meter and indicator lights in the dash will all flash rapidly. If the LCD meter and lights are flashing, return the switch to the ON position.
1. Turn off the ignition switch.
2. Remove the CVT cover.
3. Inspect and replace the drive belt as necessary according to the service manual (P/N 999241261-04).
4. Reset the Drive Belt Failure Detection switch to the ON position.
A. SWITCH
B. ON POSITION
C. CVT COVER
D. FORWARD (OFF POSITION)
5. Turn the key to the ON position and confirm that the LCD meter and lights are no longer flashing.
DRIVE BELT WARNING LIGHT CLEARING PROCEDURES
2002 KVF650-A1/B1 2004-2007 KSV700-A/B/C ALL KVF MODELS (Except KVF650-A1/B1)
2. Remove the CVT cover. 2. Inspect and replace the drive belt as necessary according to the service manual (P/N 99924-131505).
3. Inspect and replace the drive belt as necessary according to the service manual (P/N 99924-126104).
3. Remove the seat. 3. Disconnect both black and gray 4-wire connectors in the same vicinity (under the seat on KVF750 models).
NOTE: Do not connect the gray receptacle (female) connector to the black plug (male connector) or the procedure will not work.
o
5. Disconnect both sets of 4-pin connectors, and reconnect the 4pin connectors to their opposite color, i.e., gray-to-black and black- to-gray.
5. Turn the ignition switch ON.
6. Turn the ignition switch ON.
NOTE: The hour meter resets immediately when the key is turned ON.
o
6. Make sure that the belt light flashes fast 5 times at an approximately 0.4-second interval, then slowly at an approximately 1-second interval.
8. Turn the ignition switch OFF. 8. Turn the ignition switch OFF.
9. Disconnect the mismatched 4pin connector sets and reconnect them normally (black-to-black, gray-to-gray).
10. Turn the ignition switch ON and confirm that the indicator light is no longer on.
11. Turn the ignition switch ON.
thanks for this info ,its a little more informative then what iv been dealing with .one problem acording to the last paragraph these are instructions for all bikes except mine the 2002 kvf650-a1/b1.i think this might be the problem .sorry i didnt realize the there would be such a difference .once again i dont have the gray and black 4 pin plugs .i have 1 black 5 pin tha is reversable by removing a sleeve within the plug.do u have anything specificaly for the 2002 650 kvf650 .i have the kawasaki service manual and the information i need is not in that.thanks for the help .mtman
that's too bad, thought i found what you needed ... checked on kawasakiatv.com
there might be more info from that site, but when i saw this i thought it was just what the good doctor ordered. i don't have any more info or manuals pertaining to your bike either. why in hell they would publish a manual without pertinent information is beyond me. i checked thru manuals i did have from 2003 up to 2008 without a mention of resetting the light.... i'll keep an eye on anything i see for you
thanks ,using then info learned from what u sent i .i did a inteernet search on my specific model ,turns out all i have to do is to reset the switch an im good to go.well that aint happening.im still workin on it.thanks for your time .mtman
  • 2 years later...
ok i joined quad crazy just to let you know you arent the only one with this problom if you havent found this out yet here is what is going on with your quad i have the same problom your belt reset is the problom nothing else its a simple fix just switch the plugs and blaa blaa blaa O wait thats right are quads dont have two plugs to switch around thats a bunch of hourse sh*t i been dealing with this all day ok the guy i got my quad from does know how to reset the switch he is comeing over tomarrow i will be doing a youtube video of how its done and i will post it on this site as well im sorry i dont have the awnser right now but i will have the awnser and as seen as i do so will you
    • By HoldenBoy
    • By Callaway
    • By middlebrookgt
    • By Louznmemind
      I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
