Back in the game, Which sport/race quad ??
By
J-Daddy, in General ATV Discussion
Similar Tagged Content
By Guest Fox300exchic
The Hop-Up: You may be saying to yourself, “that’s a chick bike,” and you’re right. But honestly, it’s so much more than that. It’s one badass bike. http://www.quadmagazine.com/quad/features/article/0,24942,1587044,00.html
By katasha2
I took apart the carburator to clean out and I can't remember exactly where the springs that are inside the float are supposed to go I've tried to look up schematics but I think I am missing a spring maybe need helpt:confused::confused:
By skgw1
Feul pump went out. Replaced. At times quad cuts out like its not getting gas. Saw article on new pump needs to be calibrated. Told how to go into a service mode. Does not tell how to calibrate after going into mode. Can anyone shed light on this procedure.
Similar Topics
By xpnet
Hey guys I posted a while ago about my two quads but couldn't figure it out. So I gave it to my buddy he is checking them over, what do you guys think?
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By ATVNetwork
news How a recreation staple met its untimely demise.
FortNine pens a loving tribute to the three-wheeled ATC, and asks: What really killed them? View the full article
By JacobSlabach
Hey I picked up a pit bike and a foreman for 800 the pit bike was running but the foreman was locked up. Sold the pit bike but when I took the top end off the piston I only found half a piston left. So knowing the rest of the piston was down in the crankcase I knew it had to be pulled and gone thru completely.
to pull the motor I went ahead and pulled the rear end off and unbolted the front diff to pull the drive shafts and pull the motor. Now I have the motor torn down completely and have all the parts of the piston removed. I know the rod and crankshaft is shot (heat discoloration and too much up and down play rod to crankshaft).
***so I’m wondering while I have the motor apart what should I check for? I know this motor died from heat as the oil in the head smelled like popcorn. So what should I check to make sure I fix the issue (overheating I assume) and not just the symptoms (blown up motor lol).
Here’s some pics
By KX420Guy
Hey guys, Im new here but I recently Picked up a '99 Foreman 400 that apparently just had a top end rebuild. It blows white smoke like crazy and ticks/knocks and seems to follow the rpm's. I haven't done to much trouble shooting yet, It starts and runs like a champ and has good compression. I was just wondering if anyone has any suggestions as to where to go.
Oh ya the top end rebuild the guy did was according to him he honed the cylinder and replaced the piston and rings, my fear is an ovaled cylinder?
