Guest avo7100
My quad wont start after warming up unless I pump the gas pump lever mounted on the carburetor. This is even after taking the carb apart and cleaning it.
Also, the idle is not consistent. I have to adjust it both up and down after the engine gets warmed up. Anyone have a similar problem and found a solution?
Guest avo7100
Unless the fuse is inline, there is no fuse in the fuse block for the choke.
Since it doesn't have a fuse, check to see if there is 12V at the connector. If there is, your electric choke is probably shot. The symptoms are classic for an automatic choke that is not opening properly.
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
