So I got a 2003 arctic cat 400 in a trade it was sputtering a little so I drained gas and cleaned the carb. Ran good for about a day then started back. I took the carb off again and cleaned it, it had dirt in it again. While I had it off I soaked the air filter in gas and then blew it out and cleaned the intake. While I was waiting for stuff to dry I have seen where people run there snorkels straight from the carb and tun the air filter off the top of snorkel so out of curiosity I ran it like that and I made a mistake of not checking to see if my pipes had dirt in them well I ran it and after a minute or two it started smoking from the intake so I shut it off and there was sand around the inside of the intake and now it won't start back up I'm wondering what I could have messed up and what I can do to fix. Any help or advice would be greatly appreciated!!!
    • By tepin
    • By Shorty51
    • By HoldenBoy
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By spigmef
      I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
