By quadcrazy
Why Riders Like It
2. ITP Cryptid
Features
3. Outlaw 2 ATV Tires
Pros
4. STI Out & Back Max
Highlights
5. SuperATV Assassinator
Features
25-27 Inch Tires
Bias vs Radial Mud Tires
Bias Ply Tires
ATV Mud Tire Maintenance Tips
Final Thoughts
By quadnut20
What a great week to ride !! Im semi retired and plan on riding this week !! Who else is riding and where !!
By DarkRider
Hey Everybody,
Some of the features I tend to like best (aside from durability and reliability)
Durability is how long I can go without something breaking. OR how often things break with seeming not much of a good reason. Reliability is about the on-trail experience of having everything work properly as designed (i.e. Starting up and being able to get going without much issue, the 4wd drive engages without quirks, I can park it on a hill when needing to help someone else without worrying it'll roll away, etc) My Brute Force 750 is a perfect example of why Durability and Reliability were rated so differently. With durability, I really never felt like I've had anything break on the thing that was really from riding it. Which is great in that regard. But all of the things i've had to fix on it seem more so in it's design. The infamous KEBC code on the dash that refused to go away even after completely cleaning and lubing the KEBC and confirming it functions properly. Hard starting issues. 4WD requires you to roll about 10 to 15 feet to engage, so if you get stuck in 2WD, you're in a pickle. The infamous bus connector that goes bad and stops your charging system from working. I've worked through all of these, but these are all things I'd consider reliability issues that happen really at no fault of mine as I ride it pretty gently. Writing up this list has actually put a lot into perspective for me. The King Quad 300 really is a superb quad. The inclusion of the Super Low range provides stellar engine braking down pretty much any hill you can think of, it seems like it's unmatched. It has great gas mileage, and it's been dead reliable despite being a 1994. It's got 4x4 AND Diff lock, and the semi automatic transmission also help with not letting the quad get out of control down a hill. Plus it's more fun to me and gives me a bit more to do while riding. The biggest annoyance so far has been the parking brake. No matter how much I adjust it, it just doesn't seem stay adjusted after some time. I believe this might just be flawed on these models. Also, parts availability is not the greatest on these since they don't make anything newer with any similar parts. Front axles are quite expensive, rear drive shafts go for $400 to $500 brand new, etc.
And that's where the Park gear on Yamaha's Ultramatic eliminates that issue. That's where I keep landing on the older Grizzly or Kodiak 450s. They have a park gear, IRS and Diff lock, a lot of power and they're super fun to ride (got to test one). But I'd be giving up fuel efficiency and the Super Low range. The Ultramatics still have good engine braking, but still not comparable to the Super Low on Suzuki.
With ALL that said, curious about what other people out there have had and enjoyed, and I'm just looking to get some ideas of what other smaller/mid sized quads are out there with similar features. I don't really know anything about Honda, Suzuki, or Arctic Cat models from the mid 2000's.
Make Model Year Parking (gear/brake) Engine Braking Fuel Efficiency (mpg) IRS Diff Lock Durability (1-5) Reliability (1-5) Overall Rank (1-5) Suzuki King Quad 300 1994 Brake Super Low range 20 Yes Yes 4 4 4 Honda Rancher 350ES 2002 Brake (none?) 17.5 No No 5 5 4 Kawasaki Brute Force 750 2005 Brake KEBC Module 12.5 Yes Yes 4 2 3 Yamaha Grizzly 660 2006 Gear Ultramatic 12.5 Yes Yes 5 5 3 Yamaha Wolverine 450 2009 Gear Ultramatic 17.5 No No 4 5 3 Polaris Scrambler 4x4 4-Stroke 2002 Brake (none?) 14 No AWD 2 4 1 Polaris Sportsman 500 4x4 2000 Brake (none?) 15 Yes AWD 2 4 1 -
By mikeexplorer
