Hi, I have just purchased a 2002 Yamaha Kodiak 400 I think, the vin has worn off and I have located an engine number I think it is J312E-004674, could anyone tell me where the engine number might be please
you will find a vin number STAMPED into the metal frame behind the front left tire (sitting on the bike), it is just behind the fender on the frame rail. you will need a good light and need to squint (LOL), to write it down. i dont think the engine # will give you alot of info ...
after you get the vin #, you can type it in here Yamaha VIN Decoder @ Motoverse.com
Hi and thanks for the reply but the vin is completely gone from the area you pointed out, I have sanded it back lightly to take off the dirt and rust but it is completely gone, not sure what I can do now
Had a look there cant locate it so I took the piston to the dealer and they said its probably a 2002 model Thanks for your help tho.
Cheers
  • 6 years later...
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
    • By toe420
