Similar Tagged Content
By Guythis448
Looking for help on wiring up stock wiring harness specifically for a '88 Honda TRX 300
If anyone could drop a link or send me a PM it would be much appreciated
By Reece K.
I just recently bought a 1994 Yamaha Timberwolf 4x4 from a buddy who had the wheeler sitting in his garage for 7 years. I got it home and fired it up pushed it out of the garage and tried to shift it and it wouldn't shift. First it would click like it was shifting, but the wheeler wouldn't move and when I hit the gas it revved up like I was in nuetral. After trying some more it became stuck in 1st gear and wouldnt shift at all. But it later broke loose agian and acts like it is in neutral again. I took the motor off the machine to make it easier to work on.After asking friends they were convinced it was a clutch problem but after opening up the casing for the clutch I don't see anything out of the ordinary and am concerned that it may be a transmission problem. Any help would be greatly appreciated thank you.
By Guest Fox300exchic
The Hop-Up: You may be saying to yourself, “that’s a chick bike,” and you’re right. But honestly, it’s so much more than that. It’s one badass bike. http://www.quadmagazine.com/quad/features/article/0,24942,1587044,00.html
By dyyjrr9
I just got a 1991 Yamaha Moto 4 for my son and I am looking for a service repair manual. I know that the timing chain needs replaced.
By alexcross324
Hi all, I try to find this manual in the threads but you have a lot of stock here
Cannot find this particular manual.
I found it for YFM200 but not sure if they are the same.
Thanks if you could help me with that.
Im new here so if I did something wrong, please tell me.
Similar Topics
By AgmansGrizzly
Hello everyone,
Im new here, this is my first post and Im trying to figure out how evrything works on this site so I please let me know if Im doing anything wrong.
I have a couple Yamaha's but this post is in regards to my 02 Grizzly 660, I have an electrical draw somewhere that is taking my new battery down rather quickly. I have tried to locate any short by checking each circuit but was not able to locate it that way. Im installing a battery cut off switch which brings me to my first question, dont these switches usually go on the Negative terminal?
My next question is, can anyone tell me if this year and model has any history of electrical shorts that might help me locate the culprit? Any help would be greatly appreciated!
Finally, Im looking forward to being a member of this site and hopefully helping others as well as learning some things myself, so greetings to all!
Best wishes to everyone!
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By Stephanie Webb
I have a 2000 500 quadmaster lta an just rebuild the gear box an my high gear is like nuetral will not move but all other gears move nothing looks broke just need some help cant figure out what gear that would be or if it could be the shifter fork
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By Asen_77
Hi All,
My name is Asen and I am from Eastern Europe, Bulgaria. Riding a Yamaha Raptor 700R and this is my first Quad wanted for a vey long time :)
