Similar Tagged Content
By cavry
Bevinsee P15D H6M LED Headlight Bulb For Kawasaki ATV KLF220 300 KFX400 KVF300
I'm looking at replacing the headlamps on my 2001 KLF 300. These LEDs are out of my experience range. Supposedly they are "plug and play".
What problems am I not aware of? Other controllers, ballast?
Thanks, Cavry.
By Trenton
Hello. I am a new member as of today. I had a quick question to ask. I recently was driving mt HONDA RANCHER 2004 GPSscape 400 and my display stopped working. I was driving the atv and all of a sudden the speedometer and the service lights went out. Also the lights stopped working. I am still able to shift gears, change from 2wd to 4wd, and can still select if I want EPS or Auto. I have checked my fuse box and have changed a few of them around. It did not change anything. I was wondering if anyone had any idea of what had happend. Thank you for your time- Trenton
By Stoopidbot1
These are amazing.
http://www.youtube.com/watch?v=RJISYEbPF4E&feature=related
http://www.youtube.com/watch?v=toTQvuZcJCM&feature=related
Similar Topics
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By Richard Western
Hi guys,
I am hoping someone might be able to help me out. My Kawasaki 300 4x4 has an issue where it doesn't seem to want to go into neutral and also it will shift into reverse without using the lockout knob.
If anyone can suggest what to look at it would be very much appreciated.
Thanks.
By jung4g
The quad has done this off and on, almost since new, but it's gotten worse this year. Sometimes if I freshly charge the battery, it'll work fine, others times that won't matter. Turning the key to on it sounds like it's connecting as I go to the start position, slightly before the full turn, but it's not like there is just a sweet spot to find, it's totally erratic.
Now the battery is basically dead so I put a new, slightly bigger AGM battery in today to replace the factory one with all of 800 miles on it, but those have lots of plowing hours included.
I was able to get it started once, but it still went into limp mode after just a few moments of driving it (that's another topic), so I put it back in the garage and started probing around. Now it doesn't even try to turn over.
Is an ignition switch, the $18 shipped aftermarket variety on Amazon worth a shot? Or should I go straight for the starter? The new switch may not come for over a week, so I hate to just put my hopes in that if I'm missing something obvious. Fuses are good, so it's not something super obvious.
By VikingTrad3r
picked up my third timberwolf 250 for my daughters. these are great light weight little quads.
have a strange one for you. the quad will NOT start in neutral. it will start in first.
if i lift up on the gear selector just enough to hear the little click (its not loud, sounds like a contact clicking, perhaps the neutral safety switch?) the light will go out, but it won't yet be in first either. that is how i have shown my daughter to start it and she can.
id like to carry out whatever repair is needed. i have the pdf of the shop manual but it doesn't really have a flow through diagram.
any help appreciated! thank you.
i need to add something. it feels like i can switch into another gear BELOW neutral.
so if i switch to neutral, i can keep pushing the gear selector, and it has another click below the neutral. the light stays on, and when i pull up into first it kind of feels like it has two positions it moves through to arrive at first.
By Hodadical
I've inherited a 1995 Lakota 300... it has the knob in the center of the handbar to twist to go into reverse, but I've notice when downshifting, you don't have to have the knob turned, it will shift right past neutral and into reverse which is a little dicey if not all the way stopped. I followed the linkage back and twisting the knob seems to actuate the lever on the outside of the trans, the internals just don't seem to care about this.
What is the likely problem and how back is it to get to? I've never been inside of one of these transmissions.
TIA,
-Rob
