By tflack500tbx
Background,
Any Ideas?
By kevinohio
By cruteg8
Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
By sunn
Maybe someone has the answer to correct a long cranking but did start after maybe 10 seconds?
Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted. The atv started, but then died a couple times after repeated attempts. But when run awhile everything was ok. Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
Is this typical of a failing fuel pump?
I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM. Just had all covers off so looks really easy to replace.
Any ideas?
By Gtc4d
I recently purchased a raptor 80 for my grandson for christmas. I am trying to make sure it is running properly. i have rebuilt the carb and adjusted the carb idle then the mixture to middle of where it runs rough and it runs great for about a min or 2. then it stalls out. I can usually choke it and it will start so i feel it is lacking fuel. the fuel shutoff valve has been changed and i checked it for good fuel flow. any ideas of what to check next. I am planning to vfy fuel float height tomorrow. I visually checked it by turning carb upside down when i had it apart and it looked level. any ideas are appreciated.
Thanks.
Todd
