got a bayou KLF300B i believe it a 88 well i have put a new Carb and i have replaced the CDI/Rectifier/Coil/Spark plug/Reverse Cable/Diff Lock cable i have checked the stator/pickup coil and all the electrical also checked the timing and adjusted the valves it starts up easy but will not run without the choke on and wont rev past 1/4 throttle it also spits alittle gas out the back of the carb i took the new carb apart and everything is clear have tried loosing the exhaust to make sure it wasnt clogged it has a nice strong blue spark anybody have any ideas on what else to check
hi, i have the same bike, i got it as a project bike. i have rebuilt it from the frame up. i had the same stuff going on with mine, i had to replace the timing chain, i had checked the timing and it looked good but the chain was so worn it was still off. when i put the new one on it stoped all the probloms.
    • By RadRob
    • By Thumpinhard25
    • By Dumass
    • By Trent Finnessey
