2010 Can Am Spyder RTS RT-S (Tacoma)
By jwh
I am new to this site. Now down to business, I have been given a Kawasaki 220, tires are trashed and it has been setting for a long time. Do I need a battery in it to find neutral? I know there is a neutral switch and if I shift down(7 times????) then up one using the neutral switch I should be in Neutral. As you see I am in a learning curve here ......coments welcome.
By Coyote251
service manual - 2016 Can-Am Outlander L-Series
By quadcrazy
QUADCRAZY NEEDS YOU!
By Hagbard
Picked up a barn find that someone had already partially disassembled because the “motor locked up” but they never opened the case. Everything was bagged and labeled, and as I’ve mentioned before- I love a challenge ¯\_(ツ)_/¯
After a couple hours of fun with various pullers and hammers I managed to persuade the magneto/flywheel to come off. Hoo boy what a mess. Then I found an actual rats nest in the clutch cover. ಠ_ಠ
