By jeffinotown
Hey guys and gals. I've been working on my friends 2007 big bear IRS. Unfortunately after 3 different people got their hands on it and only made things worse every time. After months of finding just crazy problems everywhere. I'm finally at the point we're its almost 100% !!! But I'm getting a short somewhere between the 4xW switch I believe. I managed to by searching the internet like a fiend, got my hands on an official Yamaha wire harness for the year and make. But I don't have the numbered component list and to be honest. After hours of going through and making everything so it's easy to reference. If anyone has a picture of the referenced components. I would be forever in your debt. I've spent hours marking up the blown up diagram so it will be easy, for any possible future repairs. Please and thank you. Here's a picture of what i have so far. Unsealed it in plastic so oil and crap won't spill or get smudged. This damn things worth it's weight in gold. Thanks Jeff 2007 Yamaha big bear 400 IRS. YFM40FBW
By HoldenBoy
Hi all,
By toe420
Hello everyone, I have a 92 honda trx350 I just picked up that has a bent section of the frame where the rear of the seat would clip into place. It almost looks like a tree or something heavy fell on it. Its a fairly deep bend, if that makes sense. It like a V instead of straight. What are peoples goto methods for straightening a section like that?
By mikeexplorer
By marcosphoto
