normally there is some oil in the air breather and you should always coat the air filter with a thin coating ... you could take the air box hose off to the carb from the airbox and see if there is a mist of fuel blowing back ... could be a simple carb tweak to fix or valves could be off a hair ...
Thanks. The drain was blocked in the air box and had a lot of oil build up. Didn't realize until the blockage moved and the oil drained out onto the floor.
Will check the carb when I have time.
Just thought it was a lot of oil. I understand about coating the filter.
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
