Hey guys .. i have a suzuki ltf-160 and it starts first go but when its running it wont take full throttle without backfiring or acting like its hitting the limiter.. my friend who is a mechanic reckons its a spark problem but needed more opinions... any help i greatly appreciated
if you have good spark, it may be fuel or timing problem. i might check the carb again and remove as much you can with jets and check the needle and seat at your float. the valves are located at the top of the head, probably oval shaped covers, front and back, intake and exhaust, 2 or 3 screws/bolts holding them on. be careful taking them off, try and save the rubber O rings ...
it still sounds like an air/fuel issue ... like its not getting enough ... im not shure ware or what adjustments are on that carb .. but they prolly need adjusted..
or there is something still in the carb .. or blocking the fuel line ..
    • By kevinohio
    • By buriedpast
