just got this beast and ive ben vary happy today it just clicks its pretty froze up with ice and snow if I jump the sylinoid she will crank could it just be froze
also would like to know what oil and gas every one recommends it has after market oil cooler and stage 2 cams fully ported and polish to 11:1 compression ben using premium but should I run 110??? and what type of oil should I use in the bottom end also thanks guys
Your sylinoid may be bad or it's having a power drain cause it's
Covered in snow an ice .. I would thaw it out and make shure
There is no ice an snow on it and then try ... If it starts then that was
It if not change it ... I use only rotella 15W-40 in my machines and I've
Owned several 400ex machines and used it in them with no issues
Good luck and enjoy ...
What voltage are you getting at idle? Did you load test the battery? It might not hold a charge. Check all your connections first. every last one of them. clean em and dielectric grease them. remove your grounds and sand paper the frame underneath. then if you still have a problem let us know.
I have a 400ex with a 500 kit at 11:1. I run Rotella T6 synthetic diesel oil. I also use 93 octane with Ethanol Shield mixed in.
sprayed the entire sylanoid with wd40 and took and charged the battery and poppoppoppop lol shes alive now hopefully it will stay charged and I don't have a drain issue the rectifier or whatever its calld should charge me up if not il be back 2 square 1
stator generates the power ... regulator/rectifier keeps constant voltage ... usually the solenoid connections will spoil before anywhere else (besides the battery terminals corroding) it seems ... battery while running with volt meter should read between 14.3-14.7Vs with lights on ...
well guess its just my bad luck started rite up put it in first gear and it jus died like I kinda ran outa gas has ben running excellent do these big motors foul plugs if I run premium from caseys gas???? was told to use 110 from the 11:1 piston but was also told premium wouldn't hurt and theres a lot of snow snow so just stoppd at caseys if I really give it a lot of gas it acts like it wants to start man I hope the 440s foul plugs and it aint sumthin more
Edited by davidiz420
it has no air box lid wide open with a kn filter with pre charger I notice with the choke on it seems to be miss firing sounds really odd :mad:
I cotacted the origina owner he said it wont run anything with less than 96 octane I hapend to use 68 from caseys wich will never happen again
my question is will I have to completely remove the carb to get the 68 out or if I loosen the res tube and drain it all and wash it out with some 110 will that last little bit of 68 push it self on threw??? thanks guys
you might need a carb cleaning and while your at it let us know what #s your jets are. Clean the carb 3 times over. pull the plug and see what color it is.
looks like I mite have to take off all the plastics im gunna try just getting it done but I cant even get to the plug it seems with out taki9ng them off:aargh:
spark plug looks 20 years old there was some rust in the threads even sf416c spit fire plug can this be replaced with a ngk
also is there any way to get the gas out of the carb with out removing it???????????
got the gas out got the new plug got 110 racing fuel now all I got is to prey I didn't cause any damage I only made it 1 lap so I doubt it!!!
well good news im back in business and btw it was a bi*** getin a plug wrench to fit the ngk and the head I used the same 20 year old plug after much deliberation but after a few cranks she purs again!!! thanks for all the help guys and also u have to completely tear the bike down just to git at the plug wtf!!!
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
    • By sunn
      Maybe someone has the answer to correct a long cranking but did start after maybe 10 seconds?
      Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted.  The atv started, but then died a couple times after repeated attempts.  But when run awhile everything was ok.  Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
      Is this typical of a failing fuel pump?
      I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM.  Just had all covers off so looks really easy to replace.
      Any ideas?
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
