Dont kno if i would exactly call it a missfire but sometimes when i fist get on my quad( after letting it warm up with choke for five mins ) and rip away usually right after shifting it will miss 1 spark blow that air/fuel into exhaust and backfire then run normal sometimes itll do this 2-3 times aways in the beginning of a ride usually if i warm it up a little less then usual, just curious what would cause this. It did it since i got the quad 6 months ago and theres a different head cyl. And piston in it now...also what would cause oil to stop flowing into a head??? Or did i screw something up??? On the new head i noticed oil poors out behind cam sprocket on the old one it didnt
    • By 88bigbear
    • By Cj Winds
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
