Changed oil, removed and cleaned float, needle and seat, and carb, changed oil again, still, several gallons of gas seep I to crank case, any ideas please? Not very good at setting the float so I dread rebuilding the carb.
if you hold the carb upside down and level with the bowl off, measure the distance from the mating surface of the bowl to the top of the float, i think if you are at a half inch or less you should be good. there is a metal tab where the needle slides onto to the float to adjust if need be ...
    • By toe420
      I got a couple yamaha moto 4 225cc quads. The guy gave me several old starters with them. I see kits are available to rebuild them but does anyone have tips or tricks for doing it? I haven't rebuild a starter before so im not sure what to look out for.
    • By tflack500tbx
      Background,
      Any Ideas?
    • By cruteg8
    • By sunn
      Any ideas?
    • By Damien911
      Setting the timing on a 2005 Yamaha 250 Bruin
