By bigbell
Does any know what the stock jets are in the twin peaks?
I bought the bike with a pipe on it and want to go back to stock setup.
By p5200
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
By Kansasprairie400
Does anyone know where I can get grille letters or tailgate letters? The whole grille is solid black including the Polaris letters. Looks like they should be a different color. I found a listing on eBay for 21-22. I messaged the seller and was told they were not for a 23. Thanks, Tom
By rgeiser
just wondering if i pay the thirty dollars how soon will i be able to access the manuals?
