do you have a fuel cock on the tank ? there is an off, reserve, and on position. if it has one, the two screws can be taken out, be mindful of the rubber gasket, and you pull it staraight out and be careful of the screens ... you can clean the screens ...
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
    • By TravisCr
      I live in North Eastern Wa, in Collville, and I'm trying to figure out if there are any good regional used parts dealers around here- Our town had a decent Polaris dealer- but dealer prices are what to be expected these days.
      I've got some random little pieces I'm looking for and tired of scrolling ebay (2003 Polaris Sportsman 700)
      These are odds and ends stuff and I'll probably end up on ebay- but figured I'd ask.
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
    • By jatho
      Does anyone know what year they stopped producing the King Quad 300? - particularly in Australia and New Zealand
      What were the design changes?
    • By Clifish
      I have looked at a few threads and most are several years old.  I am looking at 2012 Honda rancher that only has a few hundred miles on it but the tires/battery are still original.  I am guessing I will need a new set?  The quad will be used on streets and rocky trails in PA.  Any recommendation for brand, type and place to buy them.  I know Amazon has them but am sometimes leery of what they sell.  How easy to dismount and mount a new set?  Any special tools or just let a shop do it?
