By Mech
View File 2022 Texron Tracker Off Road EViS service manual
2022 Texron Tracker Off Road EViS Service Manual with wiring diagrams.
Submitter Mech Submitted 11/30/2023 Category Textron Off Road UTV
By PF3
Rzr has been sitting unused inside garage for about 18 months. Engine started and run about 15 min every 1 or 2 months. Never any problem starting or running. This week took it out of town to ride for a day. Loaded, unloaded with no problems. After unloading went trailing. After about a 1/2 mile we went down a small kill and started up another hill and engine died. Restarted many times and died each time after only free seconds. Brought it home and started several times with same outcome. Changed to fresh fuel and started it. Lasted about 90 seconds (at idle) and died. So we started it several times and revved the engine up and it continued to run (while still revved up) each time until we dropped it back to idle and it died each time. HELP! Please.
By mga
on my 2k big bear 400, there's a clutch adjustment on the side that says "increase" or "decrease". Only thing service manual says to turn it one way or the other.
my question is, what happens when i decrease it? what happens if i increase it? does it effect shifting?
I'm not sure if it's ever been adjusted, but, it was tempting to play with...ut, i didn't touch it until i asked you guys.
By DannyB
According to my manual I need 25/12/10 tires. I can't find them used. Can a 25/11/10 be put on without modifications? Or anyone know of where to get the tire size I need?
By Jd101506
Hi all-
I’ve got a LT300e that I’m working on. The last two days I noticed as I’ve been testing it, it won’t turn off with the key. The kill switch still works to turn it off, as does everything else (lights, neutral light, reverse, starter, etc). So I guess I’m taking votes on what to do here… Ignition the issue? Wiring grounding issue somewhere?
Not sure where to start so any help would be appreciated!
