Hey everyone. I have been poking around this site for awhile and I am in need of yalls assistance. I have a 06 350 bruin. It has sat in my parents garage for about 2 years and was never started. I got it home, put fresh fuel and plug in it. It would start and run great but it wouldn't idle unless choke was on. Also when you were moving and let off the throttle it would make a pop noise down by the carb area. I thought it was a dirty carb so I sprayed some carb cleaner in it and didn't help.
I removed the carb, tore it down and cleaned it. I removed the jets spraying carb cleaner and compressed air thru them. I removed the float as well and cleaned. I drilled out the plug that covers the air/fuel mixture screw. I read where the spec is two turns from fully seated. So that is where I set it at. Before I did that, I removed the screw and spring and cleaned that bore out as well.
I reassembled and now I have issues. It is very hard to start, choke or no choke, and when you do get it started, you have to hold the throttle at 3/4 way to keep it running. It will run very rough at 3/4 as well. With the air filter off, while trying to start, it is blowing a lot of fuel back out into the air filter and the plug is getting fuel fouled very bad. I removed the carb again thinking I messed something up or got the float stuck but everything looked fine. I put the carb back on the second time and it didn't change a thing. I assume its something I did since its not running like it did before I tore down the carb. Can anyone please help? Thanks a lot.
check your valve clearances ... that would make it hard to start and push fuel back thru the carb ...
I was thinking about checking that but I figured if its running worse after I cleaned the carb, then I thought it was something I did. Also, with the plug removed if I hit the starter it will blow my finger off the hole.
  • 3 months later...
Almost certainly valve lash and/or burnt valve(s). My friend has one. His was doing the same thing. Adjusted the valves, found the intake valve lash at 0mm (held a bit open). Additionally, rocker not flush to the top of the valve (gap larger on one side than the other). After the valve adjustment it runs a lot better but is still lean (runs better with a bit of choke) and small pops (backfires) when backing off after high rpm. Also took the carb off. All jets clean, carb in good shape, not dirty...no issues there. It now easily runs good enough to ride...but still not quite right. I am 95+pct sure the remaining issue is slightly burnt valve as the valve-to-rocker-not-flush issue, popping, and lean condition are classic indicators of this.
They are notoriously under-powered (heavy to start with). Folks ride them and you get high rpm for extended periods. Over time this results in burnt valves (especially when the high school kids are riding the crap out of it for years).
I am having almost the same problems and I recently adjusted my valves and it ran great except for at full throttle. So, I pulled the carb and found some debris in the main jet. Put it back together and now I can't get it to run. If I pull the diaphragm with the needle it runs.
It's running really rich and I can't figure out why. I've pulled the carb and checked it at least 5 times and can't figure this one out. Any help would be greatly appreciated.
Sent from my SM-N920P using Tapatalk
Turns out when I cleaned my carb last time the main jet nozzle fell out. My kid found it on the floor in the garage. I'll update after work when I put it back in.
any one know if 95 kodiak 400 has a air adjustment screw on the carb? i know where the throttle adjuster is and where i think the fuel is but no air screw...can anyone help?
    • By Damien911
      Setting the timing on a 2005 Yamaha 250 Bruin
    • By HHurks
      Hi to all
      Newbie here. Not new to ATVs. Look forward to learning a few new things and hope to maybe help some too.
    • By BruinBeater
      I got asked to work on a pair of Yamaha 350's.  One has grizzly stickers, one has bruin stickers.  Both are 2wd, straight rear axle.  Not sure what year.  I'd guess '04-'08.
      Both have a no start condition.  Both have been sitting 2+ years.  One came with box of parts the owners 15 year old kid removed to try and get it running.
      Started working on one last night.  Pulled the rack, front plastic, fuel tank, recoil starter, carburetor.
      Removed petcock from tank, cleaned screens, made sure if flows air, reinstalled.
      Drained fuel tank, put in fresh fuel, swirled it around, letting is soak and will drain and check it later.
      Cleaned up the motor a bit since its covered in mud.  Checked the valves.  The intake had less zero, actually, probably less than zero clearance.  The valve seems like it was hanging open just a touch even at TDC.
      The exhaust had maybe .004 clearance.  I assume that went to zero once running.
      Adjust intake to .008.  Adjusted exhaust to .018
      Scrubbed the carb in a sink with a toothbrush, dawn, and water.  It looked like a mudball.
      After that, sprayed it down with carb clean and took it to the bench.  A/F screw was 1.75 turns out.  I'm thinking this is a factory setting.  It seems like this machine was never touched by a mechanic.  All the jets actually seemed clear.  The bowl had minimal residue in it.
      That about as far as I made it for the night.  Going to get a fresh plug, clean the air filter, add some fresh gas, and see if it will run.  If so, I'll probably clean up the oil cooler before putting it back together.  Maybe change the engine oil  and rear diff fluid too.
    • By TravisCr
    • By DemonQuad666
      I'm sure this has been tossed around on here numerous times but with the unveiling of the new KTM fuel injected 2 stroke. Could this be the first step in a come back for my beloved double ding ding machines. Ok lets hear it. Why do you like one or the other??? Myself, I always felt it was the throttle control and Powerband response with the 2 strokes. I know this sounds weird but on a 4 stroke, no matter size or model. I always felt like i was along for the ride instead of in control. I've spent hours on my buds 400EX, even took a new 450r for a spin. before they discontinued them. Blasters, Banshees, and a number of 125's, 250's and even one late 80's Honda XR250R... Results all the same. For me its a comfort and control that im used to with the 2 strokes.... and i love the smell of bean oil... So lets hear it. Im sick of arguing with same two people at work on this issue.
