Bought a kazuma 110 yesterday with carb issues, needs new front sprocket, and a ignition switch which is no big deal. Got the quad near dark, got from a friend so didn't think it would be a problem. Long story short their is a lot of things wrong he didn't tell me about including the rear wheels are locked up and wil not move, read on other forums that the rear diff was more than likely screwed up. Was wondering if anyone knew where I could get a rear diff rebuild kit for a kazuma because I cant find one online, Does it have to be a kazuma rebuild kit? how much do you think a mechanic would charge to rebuild? Any other suggestions would be appreciated greatly!
    • By jeffinotown
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By TomJulio
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
