Make sure you watch the video in 1080p. And all the ride info is on the video page, so no reason to rewrite it here. 34.gif
[ame]
[/ame]
    • By mikeexplorer
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
      This is from my side drive to the top of the property.
      The Dog loves the runs.
      No snowflakes were injured in the production of this video.
      https://youtu.be/tKjBFuHCkM0
    • By Hungus
      Hey guys, I know a 2000 Yamaha Big Bear 400 4x4 5 speed single range transmission is model: YFM400FM
      But what is the model designation for:
      2000 Yamaha Big Bear 400 4x4 "Professional" 5 speed dual range transmission...   YFM400F??
      VIN decoders don't seem to work for this Yamaha I picked up.
    • By Rich1028
      Video from last Saturday on the Denton Trails...PONDS!
