I cleaned my carb on my 160 1991 and then was using it for some mud. And when ever i would go full throttle it would jam open. I would have to kill it then push the arm of the throttle cable back into the carb. I would then be back in business. But i had it happen one more last time. I killed and was gonna try to push the cable back in but it was jammed. I took the carb apart and had to use a freakin screw drive to push the the needle out. The cable also got stretched some how so i cut the end off, took a bolt of the same size, cut the end off and used that as a new end for the cable. I kept is on by wrapping a wire around the cable and then soldering it. The shaft/sleeve thingy was full of dirt and mud so i sprayed carb cleaner in there and clean the sleeve and needle clean. I reinstalled the carb and everything and now the needle will not move...why wont it move??
take entire carb and cable off the bike (yes a pain). take apart all and clean. put together and see if cable and needle work smoothly. its easier to troubleshoot with all out and on your workbench/floor. something is missing, bent, or not installed right.
How is your carb getting full of mud? Correct that problem.
You have the sliding tube throttle valve attached to the needle jet. The tube and needle needs to slide up and down smoothly and the needle jet needs to enter and exit the jet orifice without sticking.
Clever on your throttle cable fix, however, shortening it might cause the engine to rev higher when you turn the steering. Suggest you get a new cable.
    • By Elk
      2002 Polaris Magnum 325
    • By sandman001
    • By 97kingquad
    • By Does_This_Look_Bent?
      Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
    • By Pure_Michigan
      Hello everyone.  This is a Go Cart and not a typical "ATV" but it has an engine so I'm hoping someone can help me.  It's a Helix FTX with a Manco 150cc engine.  The engine will start and idle for awhile, but will not take even a small touch of throttle.  Stalls.  It seems to take throttle and rev up when you first start it cold, but in just a minute, it will not take any throttle.  I've replaced the Fuel valve/Pump on the fuel tank with no joy.  It's a nice little cart, but without a workable engine, it's a boat anchor.  I'm not dumb when it comes to small engines, but this one has me stumped.  I'm running out of options.
      I'll mention that while it is idling, it will sort of "cough" every 6 or 8 seconds and then recover and idle again.  Eventually one of those "coughs" causes it to stall.  It will start back up pretty easily, but as I said, it absolutely will not take any throttle and then it will cough and stall a minute later.  I thought it could be timing, but there is no "adjustment" for timing on this engine.  I downloaded the user manual and it mentions nothing about timing and is pretty much useless as a service guide.  It just shows the basics.  I'm attaching the manual so you can get an idea of the machine I'm dealing with.
      Any input would be greatly appreciated.
      Kind regards,
      Don
      Manco-Helix-6150-150cc-Owners-Manual.pdf
