The quad starts but wont idle sometimes it idles high then dies.
When riding it will be fine for a while then it will cut out.
It has lots of power, is it time to rebuild the carb or is there other issues?
Check the vac tubes that provide suck to your fuel pump and petcock. If fuel in them, the diaphragms form those components are leaking.
Sent from my Passport using Tapatalk
Definitely seems like you are getting flooding from somewhere. If you dont find in these tubes. Try disconnecting and plugging your fuel line and running it dry from the float bowl to see how it behaves.
Thanks, that is perfect. I bought this quad used and its never run properly. Both those breather lines run up to the shifter and and terminate on a tree. I will need to conect them to the tank and fuel pump and check again
After many hours of frustration, I took the quad into the shop. They are telling me the timing chain may have skipped a tooth and want to tear it down. Does this make sense?
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By HoldenBoy
    • By crankin
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
