Please Need Help! Prairie carb problems.
OneManArmy
Hello everyone im in need of some serious help. I have a customers Kawasaki Prairie 300 its from around 2000 and he let it sit up for 5 to 6 years. well the carb is shot ive done everything and its too bad off but i have looked every where i cant find a replacement carb that dont cost $300-500.
Is there any other carbs that would fit this model? is the there somewhere I can order a new carb body? The two hols on the carb are 32mm and 46mm. its a kei hin cvk with this number stamped on it G437 BNDB.
okay i finally got the atv running but if hit another issue. it ildes high and when at the lowest adjustment the throttle cable isnt long enough to lower idle and it hunts and back fires when gas is given. it is idling to fast to put into gear. please help.
    • By hardcastle
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By Its-always-something
    • By kiriyaaoi
