Can Am Power
    • By Banshee898
      2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
      Thanks for any help.
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
    • By mkibbe
      My 2014 750 king quad stalls sometimes when I touch or turn the handlebars,the problem has gotten worse,my machine has 475 miles and is only trail ridden,I have a new factory battery and i have 14.2 volts when the quad is running and 13.3 on the battery when not running,also using a multimeter there is no change in volts when turning the bars until it does stall,If I pull the 40 amp power steering fuse it will not stall.......I've been told its the ECU,Hate to buy one if thats not the problem,but its kinda leaning towards that,,,,,need some opinions.
      If you're an outdoor enthusiast looking for adventure and off-road fun, an all-terrain vehicle (ATV) is an excellent choice. ATVs have become increasingly popular over the years, offering power, versatility, and excitement for riders of all skill levels. As we dive into 2023, let's take a look at some of the best ATVs the market has to offer.
      1. Yamaha Grizzly 700
      The Yamaha Grizzly 700 is a top contender in the ATV world. Its powerful 686cc engine delivers excellent performance, whether you're traversing rugged terrains or towing heavy loads. With Yamaha's Ultramatic transmission, the Grizzly 700 offers smooth and seamless gear shifting, making it a joy to ride. Its advanced suspension system ensures superior handling and comfort, while features like electronic power steering and On-Command 4WD add to its versatility.
      2. Polaris Sportsman XP 1000
      The Polaris Sportsman XP 1000 is another top-rated ATV known for its power and performance. Equipped with a 952cc engine, it delivers impressive acceleration and speed, perfect for adrenaline junkies. Its high ground clearance and active descent control provide excellent off-road capabilities, while the electronic power steering ensures easy maneuverability. The Sportsman XP 1000 also offers ample storage space, making it a practical choice for longer adventures.
      3. Can-Am Outlander X mr 1000R
      The Can-Am Outlander X mr 1000R is designed for those who crave extreme off-roading experiences. With a 976cc engine and a specially designed mud-ready transmission, it's built to tackle the toughest terrains. The Outlander X mr 1000R features snorkel air intake and relocate differential breathers to provide exceptional water fording capabilities. Its aggressive mud tires and sturdy suspension ensure maximum traction and durability, making it an ideal choice for off-road enthusiasts.
      4. Honda FourTrax Rancher
      The Honda FourTrax Rancher is a reliable and versatile ATV suitable for a variety of outdoor activities. Powered by a 420cc engine, it offers smooth power delivery and excellent fuel efficiency. Its compact size and lightweight design make it maneuverable in tight trails, while the independent rear suspension provides a comfortable ride. The FourTrax Rancher also features Honda's Electric Shift Program, allowing you to effortlessly change gears with the push of a button.
      As you explore the market for your next ATV adventure, keep these top 2023 models in mind. Whether you prioritize power, versatility, or reliability, these ATVs offer exceptional performance and features to enhance your off-road experiences. Get ready to embrace the thrill of the outdoors and take on new adventures with one of these remarkable machines!
      Do you agree? Comment below
    • By bco20
      just bought a brute force 750  2014 864 miles on it any common problems with them or anything for preventive maint.? will be doing some trail riding and snow plowing when neeed thanks
