Found this system and have tried it on my quad (and bikes) had to mod the mount a little to fit my wider bars but that was simple with some aluminum flat stock adding 2" to each side. Simple wiring and all in one unit so did not have to bury an amp....loaded it up with music and also use my bluetooth on phone...wanted to share....its on ebay under firehousetechnology . wanted to share will post more as I ride more but so far so good and simple addition! They are on facebook also under firehouse technology if you wanted to see what they posted
Here is video link to there initial post and video
?type=1&theater
  • 3 years later...
    • By Eisenmatt17803
      Good Morning!
      Thanks in advance.
    • By Arizona
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
    • By davefrombc
      I added a pdf of  the wiring of the various connectors used in vehicle socket  and trailer plug wiring to the  "Other ATV files"  section in downloads.
    • By neilroy87
