I have a timberwolf that I love. It sat and the carb got gel from this wonderful ethanol. I cleaned it and put a new kit in it. it always started right off. now it cranks forever before it hits and then it will not idle. set according to instructions 23mm float, 4th notch on the pin, 1 1/2 turns out on the AIS. I have tried tweeking all of these some but nothing seems to make a difference. The biggest problem is that I got it back out because the wife has claimed this bike and now it will not run for her. Any help would sure get me out of a bind.
    • By Jdeaton011989
    • By davefrombc
      1992-98 Yamaha YFB250 Timberwolf 2WD service manual
      View File Service/Repair manual 1992-98 Yamaha YFB250 Timberwolf 2WD
      Submitter davefrombc Submitted 08/06/2017 Category Yamaha ATV
    • By BillR94
      Thank you for your time
      Bill
    • By middlebrookgt
    • By hunky
      Thanks for looking!
