My 2000 suzuki quadrunner 500 has a leak at the rear of the crank case cover. You can see the oil very lightly spitting out when you look at it from the rear. I first found the bolt loose and I tighten it just lightly (I think they say 8 ft pounds). That stop part of the leak, but you can still see it coming out at the gasket between the two halves.
I am mechanically inclined, but was just wondering if there are any surprises I might be aware of when I take off the pull cord assembly, shifter ext.
Do you think there could be any other issues when I get it apart?? Doesn't appear to be any crack and I can see it just slightly spay out right in one little spot where the bolt is.
Any help is appreciated.
Edited by greatwhite
    • By Tim Keiper
    • By Frank Angerano
